Diagram for the serpentine belt?
ANONYMOUS
  • 2001 JEEP CHEROKEE
  • 143,000 MILES
I need a routing diagram for the serpentine belt on a 6 cyl. Inline.
Friday, March 29th, 2013 AT 12:39 AM
HMAC300
  • 48,601 POSTS
Always replace tensioner when replacing belt if it has an automatic tensioner here isa guide to walk you through with diagrams below to show you how on our car.
https://www.2carpros.com/articles/replace-serpentine-belt
Friday, March 29th, 2013 AT 2:15 PM
KEVSUFFOLK
  • 1996 JEEP CHEROKEE
  • 90,000 MILES
The car developed a water leak and rattle. I have been told I need to replace the water pump. While looking in the Haynes manual, online and at the sticker in the engine bay, I have realised that the drive belt routing on the engine is different from all of the diagrams. The result of which causes the water pump to turn in the opposite direction. Is there any logical reason for this or was the last belt just installed incorrectly? The car ran fine, no over heating etc, before the water leak.
Tuesday, April 2nd, 2019 AT 4:37 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Which engine do you have?
If all the diagrams I checked through, the water pump turns opposite to the crankshaft direction of turning.
KEVSUFFOLK
It's a 4lt. With a LPG conversion.
I have just reviewed the belt routing and the route will in fact turn the water pump in the right direction. I'm still a little confused however as to why the belt was not installed as per the diagram.
Thanks for your help.
Tuesday, April 2nd, 2019 AT 4:38 PM (Merged)
KHLOW2008
  • 41,815 POSTS
I have 3 diagrams here for the 4.0 L engine. Does any match your vehicle?
LONEWOLFREBEL1
  • 1997 JEEP CHEROKEE
  • 4 CYL
  • 4WD
  • 10,500 MILES
1997 jeep grand cherokee laredo straight 6 need to know how to route the serpintine belt it came off.
JDL
  • 16,098 POSTS
This is for a 4.0L grand cherokee.
https://www.2carpros.com/forum/automotive_pictures/170934_grand_cherokee_belt_routing_1.jpg
SASPAZ2
  • 6 CYL
  • 4WD
  • MANUAL
  • 155,000 MILES
How do I go about replacing the serpantine belt on my 1996 jeep cherokee 4.0l 6 cyl w/ air condionting?
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_38.jpg
You have to loosen the idler nut and then adjusting bolt
that will loosen the belt allowing you to remove it and replace
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
