1997 Jeep Cherokee Engine occasionally dies
RAZAPALA
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 154,000 MILES
My Jeep runs great, but occasionally the engine will shut-down. I have checked the fuel system and everything is OK. I have changed the ignition switch and checked all connections. No check engine light comes on and the problem is sporadic. When it does die-out if you wait a couple of minutes it will restart and run just fine. Does anyone have any thoughts?
Do you
have the same problem?
Monday, March 1st, 2010 AT 11:49 AM
TGFISHEL
Sounds like your crank shaft sensor
Monday, March 1st, 2010 AT 11:13 PM
Recommended Guides
