1994 Jeep Cherokee ignition
JDROCK
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 130,000 MILES
My 1994 jeep cherokee problem is that today while my wife was driving, she said that she could not completely turn the ignition off. Then she got it turned off but it was hard. I checked it out and the key was hard at first but began turning fine. However, now when starting it, the front wipers, radio and ac unit does not turn on. They will turn on when the vehicle is in aux mode. From what I can see, the fuses are fine and everything else work but those mentioned. My check engine light would come on periodically before this but has since stopped. I was told maybe in the ignition switch or steering column. Can you help?
Do you
have the same problem?
Monday, March 8th, 2010 AT 2:00 AM
Sounds more like the ignition switch-
Monday, March 8th, 2010 AT 4:59 AM
Recommended Guides
