If the voltage circuits are all ok, check the ground at the headlamp connector, black wire. One way to check ground, is to use a testlite connected to battery voltage, touch to black wire terminal, with connector loose, if the lite comes on, the ground is good.
Image (Click to make bigger)
Monday, November 29th, 2010 AT 4:00 PM
