1994 Jaguar XJR
1989JAGXJS
  • 1994 JAGUAR XJR
  • 6 CYL
  • 170,000 MILES
I recently bought this car to start it was fine now she runs rough even when hot and if you try to use full engine power(plant the acelarater) she shudders and jumps gains no speed but even when hot up to any speed she will not allow power to be used if drive grandad style the cr is ok if you push her then the next time you use her she will refuse to start then run worse than a tractor
Do you
have the same problem?
Tuesday, July 28th, 2009 AT 7:03 AM
DAVE H
  • EXPERT
Have the vehicle compression tested
Sunday, January 17th, 2010 AT 7:05 AM
Recommended Guides
