1999 Jaguar XJ8 loss of power
TONYHARKIN
  • 1999 JAGUAR XJ8
  • V8
  • 75,000 MILES
After steady high speed (80 mph) cruising if you decelerate on the overrun the engine appears to cut out i.E. No power if you attempt to accelerate. You then have to put the car in neutral as it decelerates and start the car normally. It always starts instantly and you just re0select drive and continue. It is most strange. What the hell is causing it?
Do you
have the same problem?
Saturday, March 7th, 2009 AT 7:03 PM
DAVE H
Replace the crankshaft position sensor
Thursday, December 31st, 2009 AT 10:18 AM
Recommended Guides
