1996 Jaguar XJ6 Recommendation for Spring Replacement front
CROWNLINER
  • 1996 JAGUAR XJ6
  • 6 CYL
  • 105,000 MILES
I replaced the shocks on my jag, but the ride didnt change. It sags on the passenger side, and the rear sits lower and sinks badly when going over bumps, like the new shocks are blown. When I go over speed bumps or uneven terrain, the rear end slams down, like it's stuck to the bottom of the car. I am guessing that the springs are bad and am probably going to replace them. Also, when going over small bumps in the road while driving the car will pull to whichever side the bump was on, it tracks badly over bumps left or right.
does this sound like a spring issue? If so what springs should I use to replace the stock equipment?
Any help would be appreciated.
Do you
have the same problem?
Tuesday, July 21st, 2009 AT 5:49 PM
DAVE H
I would replace with dealer OEM parts !
Sunday, October 25th, 2009 AT 8:06 AM
Recommended Guides
