2002 Jaguar X-Type defroster
JJW426
  • 2002 JAGUAR X-TYPE
Heater problem
2002 Jaguar X-Type 6 cyl All Wheel Drive Automatic
The car seems to fog up. The defroster will clear the windows, but upon switching to another vent format the windows fog back up. I have to leave the defroster on at all times to keep windows clear.
Do you
have the same problem?
Saturday, December 6th, 2008 AT 8:47 AM
DAVE H
VEHICLE FOGGING/CLIMATE CONTROL SLOW TO COOL VEHICLE - AIR BLEND DOOR LOOSE - REPAIR PROCEDURE
TECHNICAL SERVICE BULLETIN
Reference Number(s): XT412-02, Date of Issue: April, 2004
JAGUAR:2002-04 MY X-TYPE
VIN:C00001-D99632
Related Ref Number(s): SECTION XT412, NO. 02, XT412-02
ARTICLE BEGINNING
Issue
On some 2002-04 MY X-TYPE vehicles within the above VIN range, customers may have concerns with the vehicle interior fogging or the climate control cooling the vehicle slowly.
The concern may be caused by the air inlet blend door being loose on the actuator shaft.
Action
In case of a customer complaint of the above condition on a 2002-04 MY X-TYPE vehicle within the above VIN range, first test the operation of the air inlet blend door. Set the fan speed to MAX and manually de-select the recirc button, there should be an audible difference in the climate control temperature motor noise. If the volume stays the same then the air inlet blend door is suspect.
To rectify follow the workshop procedure outlined below.
Workshop Procedure
Open door.
Turn ignition 'ON'.
Operate front seat fully rearward for access.
The air recirculation switch should be in the fresh air mode.
Turn ignition 'OFF'.
Remove the glove compartment hinge retaining screws (Fig. 1 ).
Fig. 1: Glove Compartment Hinge Screws
Courtesy of JAGUAR CARS, INC.
Remove the glove compartment retaining screws (Fig. 2 ).
Fig. 2: Glove Compartment Screws
Disconnect the glove compartment lamp electrical connector (Fig. 3 ).
Fig. 3: Glove Compartment Lamp Electrical Connector
Remove the glove compartment.
Disconnect the air inlet blend door actuator electrical connector, undo and remove the climate control upper front stepper motor securing screws and displace the climate control stepper motor and reposition to gain working access (Fig. 4 ).
Fig. 4: Climate Control Stepper Motor
Remove the air inlet blend door actuator securing screws (Fig. 5 ).
Fig. 5: Blend Door Actuator Screws
Displace and remove actuator.
On all vehicles, align the actuator shaft as follows: Connect the air inlet blend door actuator to the electrical connector, and switch the ignition 'ON'. By a combination of operating the air recirculation button 'ON/OFF' and disconnecting the electrical connector at the correct time set the shaft to the correct position. The flat opposite the curved face should be set nearest to and parallel with the line on the actuator body (Fig. 6 ).
Fig. 6: Aligning Flat Surface Of Shaft
NOTE:A DTC will be stored during the alignment procedure since the open circuit will be detected.
Ensure the air inlet blend door is in the fresh air position.
CAUTION:Care must be taken not to apply too much adhesive as this could be pushed backwards on the motor housing when inserted in the climate control unit.
Apply Super Glue Gel or a suitable locally sourced adhesive to the actuator shaft (Fig. 7 ).
NOTE:Do NOT apply adhesive to the end of the actuator shaft.
Fig. 7: Apply Adhesive To Actuator Shaft
Align, install, and fully seat the actuator. Hold the actuator in position until the adhesive has set.
NOTE:Do NOT switch the ignition 'ON', or operate the air recirculation switch until ten minutes have elapsed to allow the adhesive to set.
Install and tighten actuator-securing screws.
Connect actuator electrical connector.
Reposition and install the climate control upper front stepper motor.
Install and tighten the climate control upper front stepper motor securing screws.
Install the glove compartment.
Connect the glove compartment lamp electrical connector.
Install and tighten the glove compartment retaining screws.
Install and tighten the glove compartment hinge retaining screws.
Turn ignition 'ON'.
Operate front seat to original position.
Position WDS alongside vehicle, switch 'ON' Portable Test Unit (PTU) and allow software to load.
NOTE:During previous operation, Connect PTU to vehicle via diagnostic cable.
Clear DTCs, switch 'OFF' PTU, disconnect and return WDS to original location.
Close door.
Warranty Information
Warranty claims should be submitted quoting the information found in the table below. This will result in payment of the stated time and, where applicable parts/miscellaneous expense codes as listed.
WARRANTY INFORMATION
DescriptionSROTimeCausal Part Number
Climate control recirculation failure service fix (left hand drive)76.94.550.9 hrs.C2S 3025
Saturday, October 31st, 2009 AT 8:35 PM
Recommended Guides
