Camshaft timing
CARLTHARP
  • 1994 ISUZU TROOPER
  • 147,000 MILES
I would like to know where to set the camshaft timing inside the heads. I have a V6 RLV motor. I believe I have put the timing belt on right, but would like to have information on timing settings. Its a DOHC motor. Im replacing the timing belt and I need to know how to set it up rite I put it on but it seems I didn't do it right because it only gets 60 pounds of pressure and it was fine before I took it apart so i'm not doing it rite well I hope you can help me thank you for your time.
Saturday, July 6th, 2013 AT 7:58 AM
HMAC300
  • 48,601 POSTS
Here is a guide to help you see what you are in for when doing the job and it shows the camshaft timing marks.
https://www.2carpros.com/diagrams/isuzu/trooper/1994
Cheers
Saturday, July 6th, 2013 AT 9:37 AM
