Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Image (Click to make bigger)
SPONSORED LINKS
Sunday, April 22nd, 2012 AT 11:07 PM
DMAPP05
MEMBER
1 POST
2002 ISUZU RODEO
V6
2WD
MANUAL
200,000 MILES
I need full instructions on replacing timing belt.
Tuesday, October 2nd, 2018 AT 10:07 AM
(Merged)
HMAC300
MECHANIC
See pictures for instructions. There is a tsb but does not cover your car.
Images (Click to make bigger)
(Merged)
PLEICKHARDTJ
MEMBER
1 POST
2002 ISUZU RODEO
6 CYL
2WD
AUTOMATIC
105,000 MILES
Setting cam timing on a 3.2 v 6 isuzu rodeo 2002, Also when setting the timing belt the book says top dead center on the first cyl but a site says cylender 2 so I am confused maybe you can help
(Merged)
BOSSGRUMBLER1
MEMBER
1 POST
I need help with the timing on a 2002 iszuzu rodeo 3.2 motor
SPONSORED LINKS
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
Here is a link that will show you how to replace the timing belt on both 4 and 6 cylinder engines.
I understand at the mileage I have I need to have the timing belt changed. I wa wondering if you
could tell me the labour time involved in this?
(Merged)
BLUELIGHTNIN6
MECHANIC
Approx. 3.5 labor hours to replace your vehicle's timing belt.
(Merged)
BILLTHURSTON
MEMBER
2002 ISUZU RODEO
6 CYL
4WD
AUTOMATIC
170,000 MILES
Well all I am going to give it a try and change the timing belt. Is there any advice from the pros out there? I plan to change the water pump also and the tensioner. Any help is always appreciated.
it is best for you to rent book from that link as it is quite involved and to much for us to copy/paste. you will get all the mechanic's tips as well as tsb's as you can print out what ever you want I think it rents for a week.
SPONSORED LINKS
(Merged)
JUNK214
MEMBER
2001 ISUZU RODEO
Do I need to purchase any special tooling to replace the timing belt for a 2001 Isuzu Rodeo? Also, how do I differentiate the tension pulley from the rest of the pulley?
(Merged)
DOCFIXIT
MECHANIC
Need to know engine size
(Merged)
JUNK214
MEMBER
V6.
(Merged)
DOCFIXIT
MECHANIC
VERY complicated proceedure needs special tools LOTS of steps. Also if belt broke then valves are bent and head needs removed. If you do not have this type repair experience suggest you have this done.
(Merged)
JUNK214
MEMBER
OK, perhaps I misworded my question. I just need to replace my serpentine belt. How do I know which piece is the belt tensioner?
(Merged)
DOCFIXIT
MECHANIC
That is a lot easier no special tool just wrench on tensioner nut push down ie. Clockwise to loosen tension
(Merged)
JUNK214
MEMBER
So which item number am I loosening? I loosened Item 6 two days ago and the belt stayed tight. And thanks for your help and patience.
