1996 Isuzu Rodeo Question fluid level
PHILOCONNOR
  • 1996 ISUZU RODEO
Transmission problem
1996 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 100k miles
how do you check and add fluid to this car. I cannot find the dip stick or a place that I can add tranny fluid
the manual even came up empty.
Do you
have the same problem?
Tuesday, May 12th, 2009 AT 8:32 PM
JACK42
There are 2 drain holes in the pan, one is higher than the other. Remove the higher one, with the vehicle idling in park the fluid level should be to the top of the higher drain plug. If you suspecr fluid is low, pump a small amount into the higher hole, with a drain pan under it. Let flow out whatever amount wants to so that it is at the top of the drain
Tuesday, May 12th, 2009 AT 9:03 PM
Recommended Guides
