1995 Isuzu Rodeo Question Unable to remove rotors
DCHINN
  • 1995 ISUZU RODEO
  • 6 CYL
  • AWD
  • 148,000 MILES
I have removed the bolts and calipers but have not been able to get the rotors off. Is a gear puller or other special tool required to remove. Any tips on how to remove appreciated.
Do you
have the same problem?
Sunday, January 11th, 2009 AT 2:53 PM
BLUELIGHTNIN6
  • EXPERT
Hello
Thanks for the donation.
Rotors are usually very stubborn when trying to remove them. There is no special tool used, just a rubber headed sledge hammer/mallet. You will have to bang around on the rotor until it breaks loose. Rubber mallets are much better to use as they will not damage the rotors nearly as easily as a metal sledge hammer.
Hope this helps.
Thanks for using 2carpros. Com!
Sunday, January 11th, 2009 AT 7:06 PM
Recommended Guides
