Sometimes while driving my car will not shift out of first gear
LINDAMG7
  • 2006 FORD FREESTAR
  • 4.2L
  • 6 CYL
  • FWD
  • 153,000 MILES
The coolant over fill tank has a fast leak. When I am driving, sometimes my vehicle will not shift out of first gear. Could the fact the over fill tank is empty cause this?
Do you
have the same problem?
Saturday, December 17th, 2016 AT 8:15 PM
CJ MEDEVAC
  • EXPERT
A leak are not good!
Probably not related to the transmission problem.
transmission (other than normal fluid checks and maintenance) are complicated creatures and I recommend that you take it to a good reasonable transmission professional to deal with it. Too much at stake when I or you make things worse.
As far as the leak, maybe I can help make that all better, thus leaving you a little for the transmission professional.
This is the broken critter?
http://shop.advanceautoparts.com/web/PartSearchCmd?storeId=10151&catalogId=10051&pageId=partTypeList&suggestion=&actionSrc=Suggest&langId=-1&vehicleIdSearch=358934&vehicle_358934=2006+%3A+Ford+%3A+Freestar+Limited+%3A+4.2L+256CI+V6+FI+VIN%3A+2&vehicle_321155=1994+%3A+Jeep+%3A+Wrangler+Sahara+%3A+4.0L+242CI+L6+FI+VIN%3A+S&vehicle_65=1977+%3A+Jeep+%3A+CJ5+%3A+4.2L+258CI+L6+Carb+VIN%3A+A&vehicle_22250=1992+%3A+Ford+%3A+F-150+Pickup+%3A+5.0L+302CI+V8+FI+VIN%3A+N&vehicle_30776=1995+%3A+Chevrolet+%3A+Camaro+%3A+3.4L+207CI+V6+FI+VIN%3A+S&vehicle_42319=2000+%3A+Ford+%3A+Taurus+%3A+3.0L+181CI+V6+FI+VIN%3A+S&vehicle_161070=1998+%3A+Chrysler+%3A+Sebring+JX+%3A+2.5L+152CI+V6+FI+VIN%3A+H&vehicle_407808=2008+%3A+Ford+%3A+Fusion+S+%3A+2.3L+140CI+L4+FI+VIN%3A+Z&vehicle_167695=2003+%3A+Pontiac+%3A+Grand+Am+%3A+3.4L+207CI+V6+FI+VIN%3A+E&searchTerm=coolant+reservoir&searchedFrom=header
Now here is where purchasing parts from now on is going to save you and your pals a bundle.
I wish I had been more computer literate a lot sooner than I was.
This is killer savings! My friends, and people I run into think I am some sort of wizard or something.
Read this post, there are pictures at the end, you still may need to do a little homework to stay on top of ever changing deals. Always run "Dry Runs" to insure things are still valid and you will get the best deal you can find.
http://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
Keep us posted on progress!
The Medic
Sunday, December 18th, 2016 AT 10:38 AM
Recommended Guides
