Motor mounts?
JUNIOR1964
  • 2006 MITSUBISHI LANCER
  • 2.0L
  • 4 CYL
  • FWD
  • 171,000 MILES
How many miles that I have to replace engine and transmission mount?
Wednesday, January 18th, 2017 AT 2:48 AM
HMAC300
  • 48,601 POSTS
Unless they are broken you do not need to replace them.
Wednesday, January 18th, 2017 AT 9:59 AM
JOHNNY G.JR
  • 320 POSTS
Do you hear any clunking when transmission is put in gear, shifting?
Wednesday, January 18th, 2017 AT 11:55 AM
JUNIOR1964
  • 32 POSTS
  • 2.0L
  • 4 CYL
  • FWD
  • 175,000 MILES
I have a question about a motor and transmission mounts. Why the mechanics told me that I have to change all mounts if one or two or three mounts is good?
Sunday, September 27th, 2020 AT 12:21 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
Because they will all be deteriorated and it is best to change them all at once. They have to stand behind their work and if they only fix half the problem, they will have to deal with you again when you complain about the job.
BACKYARDMECHANICPRO
  • 6 POSTS
From that one mount being bad its putting force on the other 3 its recommended to replace all since they will detoriate over time anyways its like changing driver side brakes and not changing pass side all that will do is fight against eachother
BOBACHHAB
  • 2005 MITSUBISHI LANCER
  • 4 CYL
  • FWD
  • 65,000 MILES
Dear Sir
the upper mount on my engine is hydro mount can you tell me about it the symptoms and the risk of oil leak and if could be refilled and I don't have to change it
KHLOW2008
  • 41,815 POSTS
Hi bobachhab,
The mount seldom leaks and if they do, you would be getting black stains near the mount area.
It would mean the mounts have deteriorated and vibrations during idling, shifting into gear etc would be amplified.
Mounts are not serviceable.
GARYJAMES KINZER
  • 2002 MITSUBISHI LANCER
  • 2.2L
  • 4 CYL
  • 215,000 MILES
I am having trouble removing right front motor mount. Three bolts and three nuts from the front right motor mount, but it will not budge and come out. I have checked underneath the motor mount in the wheel well and have found no further bolts holding it down. What am I missing?
  • 52,797 POSTS
Good morning,
Can you post a picture of what you see? I want to see what you are doing. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
