I have a OBD1 error code 18
ROPER_21
  • 1993 OLDSMOBILE 88
  • 3.8L
  • V6
  • 170,000 MILES
My car started stuttering while driving across town and the check engine light cam up. I checked the codes ant the only one that has come up is error 18. I have replaced the crankshaft position sensor and was going to attempt to replace the camshaft position sensor but am unable to locate it. Otherwise the car has ran great and seems to be running smoothly. Could I get some help.
Do you
have the same problem?
Monday, January 13th, 2014 AT 11:51 AM
HMAC300
  • EXPERT
Check your plug wires that can cause that code as well. If it is missing especially. Then when finished repairing pull ecm fuse to reset light. See pic for locations.
Monday, January 13th, 2014 AT 12:00 PM
