Car will not turn over after changing the ignition switch
SHAWN JOHNSON2
  • 1991 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • TURBO
  • FWD
  • 154,010 MILES
Car battery will not keep power, but interior lights come on, dashboard lights will not come on and car will not crank over. Can I have hooked the ignition switch up wrong?
Do you
have the same problem?
Sunday, August 7th, 2016 AT 4:37 AM
RIVERMIKERAT
Maybe, if you forced the connector. Turn everything off and remove the negative battery cable. Are you seeing a spark? If so, that means there's either a short or something is not turning off. Find the starter solenoid and hook up a test light to it. Disconnect the coil and have someone turn the key to the start position. The test light should light up.
Sunday, August 7th, 2016 AT 4:35 PM
Recommended Guides
