While driving and it goes into neutral
ARTHUR DEAN
  • 1999 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 4WD
  • 200,000 MILES
When you get up to about 40 miles an hour it just quits pulling, like a neutral. You slow down or switch gears second to third and starts pulling a little, but then stops again.
My T-case is leaking a little would that cause it to slip around 40 mph?
The the little the seals leaking around the back cancel that cause a problem at 40?
Do you
have the same problem?
Thursday, October 18th, 2018 AT 7:01 PM
