Speedometer and have stopped working
ANONYMOUS
  • 2008 HYUNDAI SANTA FE
  • 85,000 MILES
My speedometer and odometer have stopped working. No idea why. How can I fix it?
Saturday, February 16th, 2013 AT 12:44 AM
  • 108,170 POSTS
It sounds like the vehicle speed sensor (VSS) has gone out here is a diagrams below to show you the location so you can replace it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, January 31st, 2019 AT 10:12 AM
TURBOJAY
Thanks for this post I had the same problem and had to get a new sensor for $66.00. All fixed! I love this site.
QUERQUECREW
  • 2007 HYUNDAI SANTA FE
  • 76,000 MILES
The last couple of days my speedometer quit working. This morning I noticed that my trip and ODO numbers were not changing (these two are digital). I am taking the car to a mechanic later today to evaluate it; but, I was curious if it is something as simple as a fuse/loose cable, or if it is more likely an electical issue (cluster issue)? Thanks for the information!
Wednesday, January 27th, 2021 AT 10:44 AM (Merged)
Hello, It sounds like the vehicle speed sensor is out here is the location so you can change it out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SANTAANA326
  • 4WD
  • 162,000 MILES
My local shop told me to purchase a new panel for the odometer-speedometer-tachometer-gas gauge, which I did. Now, not even Hyundai dealership can tell my guys how to program the odometer. Please help! Hyundai USA just referred me back to local dealership.
-Anne
94 TRANSAM
  • 680 POSTS
Hello and thank you for using 2CarPros. I am sorry for your frustration and I will do what I can to help.
In all states that I know of it is illegal to change the mileage on any odometer. Even if you can prove you set it to the same mileage. The only ones who can to my knowledge are dealerships. They can do it, but will they or do they have someone trained to do it I am sure will vary. You may need to call several to find one that will.
I am sorry, please let us know if you get it resolved. We love good news.
Rich.
BMDOUBLE
  • 1,139 POSTS
Odometers are usually programmed with the instrument cluster at the facility that rebuilds and repairs them. When I order clusters I have to tell the parts person the mileage so they can program it.
GLENNEDWARD
  • 2003 HYUNDAI SANTA FE
  • 122,962 MILES
The speedometer has stopped working. Told it could be a blown fuse. What fuse controls the speedometer? And what else could it be? I looked at both fuse boxes and could not determine which fuse is for the speedometer. Could you point me to the fuse?
HMAC300
  • 48,601 POSTS
Fuse 11, 19 and 22 in passenger compartment box under drivers side of dash. But have it scanned for codes your vehicle speed sensor may be bad
See images below for fuse block location
C17COWBOY
  • 2001 HYUNDAI SANTA FE
  • 6 CYL
  • AWD
  • 158,000 MILES
I've looked on many different websites and they all point to the VSS as the blame for the speedometer failure. At first, it wobbled up and down, then after a few days, just won't move. How do I get to the VSS and how do I replace it? Where can I go to get a replacement?
Wednesday, January 27th, 2021 AT 10:45 AM (Merged)
HI5SANTAFE
I replaced my VSS cost me $67.00 for the sensor works great!
