2001 Hyundai Santa Fe Problem with the A/C while car is idl
JORGE10928
  • 2001 HYUNDAI SANTA FE
  • 4 CYL
  • FWD
  • 111,959 MILES
When I'm driving and come to a stop like a red light and have to hold down the brakes; if my A/C is ON, the car will sometimes jump. It feels like a misfire but the RPM doesn't move. When it starts to act strange I turn off the A/C and it immediately stops. There is no MIL indicating that something is wrong. Its been like this for quite a while now and I don't know why it does it. Any help would be useful. Thanks.
Do you
have the same problem?
Tuesday, December 30th, 2008 AT 3:12 AM
JAMES W.
When your AC is on the ECM raises the engine rpms to compensate for the added load on the motor. If this signal from the AC switch to the ECM is interrupted for just an instant or the ceases to process the information, the engine will lurch forward.
Tuesday, December 30th, 2008 AT 9:57 PM
JORGE10928
Then what should I do to fix my problem?
Tuesday, December 30th, 2008 AT 11:22 PM
JAMES W.
Have your idle speed control unit checked to make sure it's in range. To do this, you will have to hook it to a scan unit.
Tuesday, December 30th, 2008 AT 11:59 PM
Recommended Guides
