1991 Other Hyundai Models Broken Fuel Gage & Broken Remo
XERXES
  • 1991 HYUNDAI
  • 4 CYL
  • FWD
  • 170,000 MILES
i have a yellow hyundai s coupe and the fuel gage does not read how much fuel is left in the tank, it just sits on empty. How would I resolve this issue.
also the remote fuel filler lid release lever does not work how would I fix that?
regards
xerxes
Do you
have the same problem?
Tuesday, August 26th, 2008 AT 7:09 AM
  • EXPERT
Hi:
The lid not opening is most likely a broken cable. Check for that. As far as the fuel gauge, chances are the float is bad in the fuel tank and not sending a signal to the gauge. To check it, you need to remove the fuel tank and check for output from the float assembly. If there is none, then it needs replaced.
Wednesday, March 4th, 2009 AT 1:30 PM
