2006 Hyundai Elantra radiator hose
RGUEVARA4
  • 2006 HYUNDAI ELANTRA
  • 4 CYL
  • 4WD
  • 62,562 MILES
Want to know what the part is called. Its the part that has a radiator hose go from the radiator to that part. The hose goes from there to the top of the radiator. It also has a sensor on it. Its right above the housing.
Do you
have the same problem?
Tuesday, June 2nd, 2009 AT 8:34 PM
  • EXPERT
I think you are refering to the thermostat housing. The upper radiator hose goes from the radiator to it. The sensor is the coolant sensor.
Monday, June 8th, 2009 AT 12:33 AM
