Brake Lights Dont Work, Even Top Bar
GRANDLAWNCARE
  • 2006 HYUNDAI ELANTRA
Electrical problem 4 cyl Front Wheel Drive Automatic 40000 miles
Both Brake Lights do not work Plus Top Brake Light bar.
I have searched this site extensively and here is a list of what I have already checked:
Fuses: All good (under hood & under console)
Brake Switch: Good=Cruise control disengages properly and continuity check on contacts show one set NO and one NC working properly.
Light Bulb:Good=Visually OK, Continuity check. Beeps from side of light to either contact on bottom of bulb & beeps from contact to contact.
The Tail lights, reverse lights, Hazard, and turn signal lights DO work.
This is the wife's car and she reported that this morning the A/C would not turn on. It is working for me right now, but thought I should add that.
My fuses are not numbered, but counting left to right and top to bottom that puts me on "S/Roof". The one next to it is "Stop" (under console). I arbitrarily replaced both of these fuses to eliminate them 100%.
I already checked the brake switch and gave my results in the initial post. I don't have a drawing for it so I could only tell you how it responded to a continuity check. With the plunger pointing down it seems logical to assume the top contacts are N.O. For the brake lights and the bottom set are N.C. Contacts to unlatch the cruise control.
She had her battery changed by Auto-zone about a week ago. No way of knowing how long the brake lights have been out though.
Tuesday, September 8th, 2009 AT 7:39 PM
GRUMPYDAN
I have a 2006 Elantra and my brake lights went out last night. Fuses and
bulbs are okay. I replaced the brake switch found at the top of the brake
pedal and that fixed the problem. It cost $12.97 from Auto Zone. Kind of a pain to get to but only took about 30 min to install. Hope this helps someone. - Dan
Here is a guide that can help as well. (Below)
Thursday, September 22nd, 2011 AT 9:47 PM
GATOENCERRADO
The most widespread Hyundai recall, affecting up to 531,894 2005-2008 Accent, Azera, Elantra, Entourage, Santa Fe, Sonata, Tucson, and Veracruz models, is NHTSA Campaign 09V122000. It is focused on a malfunctioning stop lamp switch that may prevent brake lights from illuminating when the pedal is depressed (the same switch may also cause them to stay lit after the brakes are released).
Owners of affected vehicles may contact Hyundai Customer Service at 1-800-633-5151, call the NHTSA Hotline at 1-888-327-4236, or visit SAFERCAR. GOV
If Customer Service tells you that your VIN number is not included in the recall, call NHTSA and file a complaint.
Sunday, November 6th, 2011 AT 6:22 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 104,000 MILES
I replaced my front brake pads and now my brake lights arent working. They were fine before. How do I fix it?
Wednesday, October 25th, 2017 AT 9:31 PM (Merged)
Try adjusting either the brake booster pushrod or the brake switch
ASK1212
  • 4 CYL
  • 61,000 MILES
Electrical problem
2006 Hyundai Elantra 4 cyl Two Wheel Drive Automatic 61,000 miles
My brake lights just stopped working. They were fine yesterday and not so today. Bulbs are good and the fuses are good since the other elements attached to those fuses (windows) are working.
Any ideas?
  • 108,133 POSTS
There is a brake light switch on the top of the brake pedal. Check to make sure it didn't come loose or is out of adjustment. If all is well, make sure there is power in to it (12 volts) and the same out when you hit the brakes.
Let me know what you find.
ASK1212
Thank you for your reply.
  • 108,133 POSTS
Let me know what you find. It may help others who read our notes.
GRUMPYDAN
I have a 2006 Elantra and my brake lights just went out also. I'll see what I can find out in the morning and let everyone know what the problem
is and how to fix it.
BPAGE
  • 4 CYL
  • FWD
  • 50,000 MILES
Electrical problem
2006 Hyundai Elantra 4 cyl Front Wheel Drive Automatic 50000 miles
all of my wifes brake lights are not working I checked the fuse it was good and I cant see all of them going out at one time what elase can I look for
BLUELIGHTNIN6
  • 16,542 POSTS
Check the brake light switch, driver side dash on brake pedal arm bracket. It may be out of adjustment or faulty.
JESSESIXTY8
  • 2002 HYUNDAI ELANTRA
  • 4 CYL
  • MANUAL
  • 46,000 MILES
Brakes problem
2002 Hyundai Elantra 4 cyl Two Wheel Drive Manual 46,000 miles
Brake lights not working, just the two above the bumper the third tail light works fine: I checked the fuse and the bulbs and they are fine: where else could the problem be I believe it may be in the wiring harness? But not sure can you help. Thanks
Inspect and test the brake switch at the brake pedal support-at the brake switch connector check for power at the red wire on the connector. No power there check fuse no.16 15amp.
ELSOLDEL
  • 2008 HYUNDAI ELANTRA
  • 80,000 MILES
But flasher and reverse lights do work for my 2008 Hyundai Elantra, what is the problem? Also having trouble shifting into reverse
HMAC300
  • 48,601 POSTS
Is it a stick or automatic? Check your brake light switch and relay
Wednesday, October 25th, 2017 AT 9:32 PM (Merged)
BIGTINTUSA
  • 2007 HYUNDAI ELANTRA
2007 Hyundai Elantra
Brake lights don't work. Taillights work and signal lights light up but no brake lights. I'm thinking this is a fuse but have no idea where the fuse for the brake lights are. Don't have a manual. Can you help?
  • 108,133 POSTS
I believe they are under the dash on the driver's side. Also, check to make sure the brake light switch isn't out of adjustment. It's on the top of the brake pedal.
DMABOOD
  • 2003 HYUNDAI ELANTRA
  • 4 CYL
  • MANUAL
  • 100,000 MILES
Electrical problem
2003 Hyundai Elantra 4 cyl Two Wheel Drive Manual 100000 miles
In the past few months, when I depressed the brake pedal, the lights on my dashboard would come on when the lights were off. Then today, I was told I had no brake lights at all. When I turned the car lights on - my brake lights would come on (though I believe one of my brake lights are burned out). What could be the problem? Also - my cruise control works sporadically - could this be connected to the brake light issue?
KHLOW2008
  • 41,815 POSTS
Hi dmabood,
If the brake lights and cruise controls are working intermittently, it could be a fault with the brake switch.
Turning the lights on would illuminate the taillight and not the brake lights. They are in the same bulb but a different circuit.
2CP-ARCHIVES
  • 4,542 POSTS
  • 2009 HYUNDAI ELANTRA
  • 83,000 MILES
My brake lights quit working. The bulbs are good after replacing the bulb in the back windshield. The fuses are good also so why won't my brake lights work
