2003 Hyundai Elantra No Torque
HELANTRAGT
  • 2003 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 92,000 MILES
I was going up a hill in fifth or fourth I do not recall, and was at very high RPMS. I was getting very very little torque and when I stopped I could barely move. I was getting very very little torque. I was told to bleed the clutch and then add more fluid. But I am not sure if the car will self adjust. If this does not work what do I do? And what kind of fluid do I put back into the clutch fluid resevoir? Thanks.
Do you
have the same problem?
Saturday, July 11th, 2009 AT 5:52 PM
  • EXPERT
HI there,
The clutch hydraulic system uses normal brake fluid, if the level is ok and you have good pedal pressure the system will be ok, there is no adjustment on this clutch it is done automatically as the clutch wears, I feel that the clutch is worn out and requires replacing, have this checked, a mechanic will be able to tell you this with a test drive.
Mark (mhpautos)
Saturday, July 11th, 2009 AT 6:46 PM
Recommended Guides
