Battery problems?
CALVINJWATTS
  • 2008 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 35,000 MILES
My 08 hyundai elantra would not start up this morning, it would not even turn over. When I got inside this morning I noticed the dash lights and auto window lights and cigar light all flashing in unison. Is this the car telling me the battery is shot or something else?
Friday, December 17th, 2010 AT 7:03 PM
SATURNTECH9
  • 30,870 POSTS
The first thing I would do is have the battery charged and tested. You could have a bad battery do you have a multimeter to take a voltage reading on the battery?If not get that battery charged and tested. Let me know what you find.
Friday, December 17th, 2010 AT 7:55 PM
CALVINJWATTS
Turns out it is the battery. When the bat. Drops below 5 volts the car flashes dash lights on and off till fixed. Crazy never seen anything like it.
Monday, December 20th, 2010 AT 3:55 PM
SATURNTECH9
  • 30,870 POSTS
Glad to hear you got it all figured out that's what we like to hear.
Tuesday, December 21st, 2010 AT 12:54 AM
OKIETIGER
  • 2005 HYUNDAI ELANTRA
  • 4 CYL
  • 56,000 MILES
The battery died and is it safe to put a charger on the battery over night?
Thursday, April 9th, 2020 AT 12:22 PM (Merged)
  • 108,170 POSTS
The number of hours that a battery needs to charge is based on the number of amps the charger is. For example, if you have a 1 amp charger, you could let it go for a couple days and not hurt anything. If you have a 10 amp charger, 4 hours should do it.
CHEFTONY
  • 2002 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 135,000 MILES
Put in a battery, turn ignition, engine starts, turns off ignition. Returns 10 minutes battery have not enough to start vehicle.
  • 108,170 POSTS
I need you to check for an electrical draw. If there is one, remove one fuse at a time until the draw stops. Here are the directions for checking for a draw:
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
