Squealing
KEYTA97
  • 2003 HYUNDAI ELANTRA
When I start my car there is a squealing (sounds like a belt) that goes on for 5-30 seconds and then stops. The same squealing can sometimes be heard when I make a turn. Also, when the car is cold the steering wheel is difficult to turn.
Thursday, January 22nd, 2009 AT 11:11 AM
  • 108,170 POSTS
It sounds like the power steering pump is loose. You should not have more than 1/2 inch up and down play. If there is more, adjust or replace the belt.
1. Press the V belt, applying a pressure of 98 N (10 kg, 22 lbs.) At the specified point and measure the deflection to confirm that it is within the standard value.
Standard value
V belt deflection: 6 - 9 mm
2. If the belt deflection is beyond the standard value, adjust the belt tension as follows.
1. Loosen the bolt adjusting the power steering "V" belt tension.
2. Put a bar or equivalent, between the bracket and the oil pump and adjust the tension so that the belt deflection is within the standard value.
3. Tighten the bolt adjusting the power steering "V" belt tension.
4. Check the belt deflection and adjust it again if necessary.
Let me know what you find.
See the diagrams below
Tuesday, March 24th, 2009 AT 12:48 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 4 CYL
  • 142,000 MILES
I have a 2003 Hyundai Elantra with 142,000 miles. Which progressively got worse. After a few weeks the squealing continued and when you turn the steering wheel, the pump will shut off and all power steering is lost. We've changed the pump, ps belt and the rack and still have the squealing problem with the pump shutting off. Does you have any idea what we should try next? This has been a very frustrating problem. We were considering changing the ball joints but are not sure if this will fix it.
Wednesday, December 12th, 2018 AT 6:05 PM (Merged)
2CP-ARCHIVES
  • 4,542 POSTS
Is the P/S belt by its self or is this a serpentine belt (one belt for everything)? If serpentine I would check the drive belt tensioner, might be too weak to hold tension against a hydraulic pump.
LORI6268
  • 2010 HYUNDAI ELANTRA
  • 2.0L
  • 4 CYL
  • FWD
  • 108,000 MILES
I recently had the timing belt, water pump, serpentine belts (alternator and A/C compressor) and tension-er pulley all changed and I still have a squealing sound when I start my car. The sound is prevalent when the engine is cold, but after running a few minutes, the sound stops. My nephew did the work for me and he is at a loss as to what could be causing it. Any ideas as to what the problem could be? I did not have this issue before all the work was done. Thanks for the help.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,878 POSTS
It sounds like the belt tensioner is not doing its job correctly or not adjusted right, but to be sure remove the serpentine belts and start the car to see if the noise is gone. This will confirm the belt is the problem.
If so then double check the size of the belt and make sure the tensioner spring is working correctly. Here is a diagram (below).
https://www.2carpros.com/articles/replace-serpentine-belt
and
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
LORI6268
Hi Ken. Thanks for getting to my previous Q concerning the issue I had with my Elantra. As it turned out, it was the alternator that was the cause of the noise. I bought a new one and the squealing sound is gone. Thank God! Thanks again for your help! Have a Blessed Day!
KEN L
  • 42,878 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
FJLABARBERA
  • 8 POSTS
  • 2002 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 78,000 MILES
When turning the steering wheel, there is a screaching noise. Visual indicated that the pump pulley almost stops. If the steering is returned to straight ahead, the squealing stops. Adjusted the belt tighter than spec with no change. Is this a pump problem. Plugged filter, or?
MERLIN2021
  • 17,250 POSTS
If the tension on the belt is good, check the fluid level, and if OK, the pump, or rack is bad.
FJLABARBERA
  • 8 POSTS
The fluid level is ok. Is there a way to check the pump or do I have to replace it first to see if it fixes the problem?
MERLIN2021
  • 17,250 POSTS
SYSTEM TESTS STEERING PUMP PRESSURE TEST 1. Disconnect pressure hose from oil pump. Install pressure tester between pump and pressure hose using Gauge (09572-22100) and Adapter (09572-22000). See Fig. 1 . See SPECIAL TOOLS . 2. Bleed air from system. Start engine and allow it to idle. Turn steering wheel lock-to-lock several times until fluid temperature reaches 122 °F (50 °C). Raise engine idle speed to 1000 RPM. 3. Close and open shutoff valve to measure fluid pressure. Relief pressure should be at or near specification. See RELIEF PRESSURE SPECIFICATIONS table. If relief pressure is not as specified, replace pump. See POWER STEERING PUMP under REMOVAL & INSTALLATION.
CAUTION: DO NOT leave shutoff valve on pressure gauge closed more than 10 seconds, or damage to oil pump will result.
https://www.2carpros.com/forum/automotive_pictures/62217_elantraa_2.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_elantra_2.jpg
CMAJAY
I have a 2002 Hyundai Elantra GLS When starting the car I am hearing a squealing sound like a belt slipping & the steering wheel buck when I try to turn it, when I start the car. I have checked the belts & Power steering fluid levels they are all good. Is this an indication that the power steering pump is going bad?
I have checked the belts & Power Steering Fluid Levels they are all fine.
I love this site!
  • 108,170 POSTS
It could be; however, are you certain the belt is tight enough?
CMAJAY
Yes per my owner's manual & a ruler I checked/measured the amount of play in the belt right at 5.1cm plus I just had all the belts replaced when I had the car serviced 3 months ago
  • 108,170 POSTS
What I suggest is to remove the belt and check to see if any of the belt driven accessories are free and not locking up.
TPOLFER
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • 4WD
  • 101,000 MILES
I just replaced all three belts in my 2000 hyundai and ever since then one of the belts have been squealing. The car starts squealing when I turn on the car and lasts for about 2 minutes and then when the car heats up, the belts squeal when I either turn the car or when I stop at a stop light and then accelerate. But these squeals are not consistent, they happen at random times. Belt oil (or the thing they put on squealing belts) helps for a bit, but only for a few days at most.
  • 108,170 POSTS
Chances are the belts have stretched. I would retighten them. As far as the steering, that would be the PS belt. As far as the noise when you start it, chances are that is from the alt belt.
Let me know if you find the problem.
JOEY MACK
  • 2004 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 80,000 MILES
First time cars started after its been sitting for a while a power steering belt squeals. The belt has been changed and is tight. It appears the power steering pump stops turning breifley. It did not have this promblem before the belt had been changed.
  • 31,938 POSTS
Hi there,
If the pump is faulty and showing signs of seizing, I would be replacing it, may be you can get the pump operation tested first, just to make sure.
Mark (mhpautos)
BOWLU
  • 4 CYL
  • FWD
  • 188,000 MILES
When I reverse or have it in drive and slightly turn the staring wheel there let's out a really loud squeal noise, I just drove on the highway for about a 2 hour trip and this noise has started. I recently got my oil changed and all my fluids topped up. So I'm wondering if it has to do with my power steering or possibly my belt. Also I have another issue as well when I'm accelerating I hear a loud humming noise I'm wondering if those are my bearings that may also need to be changed.
