1997 Hyundai Accent Cylinder 2 Misfire
NELSONAK
  • 1997 HYUNDAI ACCENT
Engine Performance problem
1997 Hyundai Accent 4 cyl Automatic 100000 miles
Recently my check engine light went on, and after checking it out, we found that there was a misfire in the second cylinder. We checked the wires, coil, and plugs. When we found that the second cylinder was running dark we replaces the spark plugs as well as the corresponding fuel injector. However, no change has occurred, the plug is still running rich. We are full out of ideas, PLEASE help!
Do you
have the same problem?
Saturday, October 16th, 2010 AT 9:23 PM
Check the compression for that cylinder
Sunday, October 17th, 2010 AT 1:21 AM
Recommended Guides
