Signal lights don't flash and no hazard lights
ILOVEMYSELF1
  • 2008 MAZDA 6
When I turn my signal light on it doesn't flashnor do I have any hazard lights I woulf like to know whats causing this problem?
Sunday, February 16th, 2014 AT 3:31 PM
CADIEMAN
  • 3,544 POSTS
Check all signal bulbs. Do the brake lights work?Please try to donate when you can thank you
Tuesday, February 26th, 2019 AT 10:41 AM
ADAM CUNNINGHAM
  • 2007 MAZDA 6
  • 3.0L
  • V6
  • 79,000 MILES
Right turn signal turns on hazard lights, as well as all turn signals hyper-flash. I have rear turn signal led's installed but have resistors connected to them. Any help is appreciated. Thanks.
Thursday, June 18th, 2020 AT 1:31 PM (Merged)
HMAC300
  • 48,601 POSTS
It may be due to the bulbs you put in put the normal ones in and see if it does it. The resistors may be the problem.
ADAM CUNNINGHAM
Whoops threw those away a long time ago. I will temporarily take off the resistors and get back to you okay?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
Sounds good, please let us know asap so it can help others
KARDEJAH ANDERSON
  • 2006 MAZDA 6
  • 4WD
  • 143,130 MILES
My turn signals and hazard lights will not come on. And it is not the bulb, but I do not know which fuse controls my turn signals.
KEN L
  • 42,882 POSTS
Lets get the problem fixed, the fuses are a great start. Here is a guide and some diagrams to help you check the fuses. Key on engine off.
Cheers, Ken
GLORIA JEAN
  • 2003 MAZDA 6
  • 2.3L
  • 4 CYL
  • MANUAL
  • 230,000 MILES
Hazard lights will turn on by themselves while driving or if the car is parked & not in operation.
I push the hazard light switch to try & stop it, sometimes it will stop, sometimes will not. A buzzing sound is heard while the hazard lights do it.
Have had the electrical system scanned, no problems showed.
Can anyone shed some light on this problem.
Other road uses are not impressed by this problem including the police.
I am an aged pensioner also disabled & cannot be without my vehicle.
Thursday, June 18th, 2020 AT 1:32 PM (Merged)
HMAC300
  • 48,601 POSTS
It sound like the flasher module has gone out which is behind the cluster here is a diagram to show you the location and how to change it out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
TIMMCGRAW313
I had this problem it was the flasher got a new one for $34.00 all fixed
