How to remove key from ignition
ANICKERSON01
  • 1999 FORD MUSTANG
  • 4 CYL
Having trouble getting my key out of the ignition. My car went into theft lock and now my key will not come out of the ignition and I only received one key when purchased my car.
Do you
have the same problem?
Monday, March 2nd, 2015 AT 9:31 PM
DR LOOT
  • EXPERT
Tell me the procedure you used to remove the key? Are you sure the vehicle is in park? Doublecheck. Is the steering wheel locked? Try wiggling the steering wheel back and forth and remove the pressure, in other words if the steering wheel is turned in a locked position turn the wheel hard towards the way it is turned and see if the lock will move on or off
Wednesday, March 4th, 2015 AT 7:37 AM
Recommended Guides
