Removing lower control arm
LRDAYE
  • 2002 CHRYSLER SEBRING
I am trying to remove the lower control arm (drivers) side and I am running into clearance problems with on one of the control bolts hitting the bottom end of the engine. I have pulled the front engine mount bolt and tried jacking the engine up but I am still need a 1/2 clearance to get the bolt out.
Suggestions?
Wednesday, September 8th, 2010 AT 9:20 AM
DOCFIXIT
  • 18,828 POSTS
Have you removed stablizer
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_608.jpg
Remove control arm from crossmember
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_151.jpg
Then unbolt rear
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_4_36.jpg
is bolt 5 the one causing trouble? droping cross member will allow bolt to miss engine
Wednesday, September 8th, 2010 AT 10:32 AM
LRDAYE
Yes, bolt 5 is the problem. It is hitting the bottom of the transmission
Wednesday, September 8th, 2010 AT 11:28 AM
LRDAYE
Here is a picture of the bolt.....drop the cross member...this has turned into a big job !
https://www.2carpros.com/forum/automotive_pictures/570571_0908101134a_2.jpg
Wednesday, September 8th, 2010 AT 11:48 AM
DOCFIXIT
  • 18,828 POSTS
Remove jack stand from crossmember remove bolt #2 in PIC 2 this will let crossmember to drop clearing trans.
Also may need to jack up trans use block of wood on jack saddle
Wednesday, September 8th, 2010 AT 3:08 PM
ABISAI ESPINOZA
Hello I am new here, can anybody help me on this as well? I am running in to clearance problems as well, please any advice, thank you in advance.
Wednesday, October 24th, 2018 AT 8:36 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Yes, you are to loosen the cradle bolts and support it using a jack because the engine is connected to it (heavy). Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Friday, October 26th, 2018 AT 12:41 PM
TANDRA223
  • 111 MILES
I have a 02 chrsyler sebring I just replace the lower ball joint wit the control ARM so now there a noise under the car sounds like something dragging. I pull the peace that I thought was the problem but that wasn't it please help me
Friday, October 26th, 2018 AT 12:41 PM (Merged)
  • 108,170 POSTS
Check control arm bushings and check stabalizer links.
FERLINM
  • 5 POSTS
  • 2.7L
  • 6 CYL
  • 220,000 MILES
In the process of changing the driver's side lower control arm I ended up braking a bolt (to the body mount I think). I have looked everywhere and cannot find a way to the top of the bolt.
Tuesday, August 11th, 2020 AT 5:26 PM (Merged)
  • 52,797 POSTS
Good morning.
Can you post a picture of the broken bolt so I can see what you see?
Are you sure it is not a cradle bolt?
FERLINM
  • 5 POSTS
I am at work right now, but I will send a picture in a couple hours. We broke the bolt loose but it just spins in the hole and when I try to tighten it down it tightens about half a turn and breaks loose again so I can only assume it is broken since I cannot see the top. Also, lately I have been hearing a small popping sound. Could just be a loose nut, but I do not think so
  • 52,797 POSTS
It sounds like the nut is spinning at the other end.
Yes, please send me a picture.
FERLINM
  • 5 POSTS
From what I have seen I am going to have to cut a hole in the floor board and possibly the sub-frame.
  • 52,797 POSTS
The nut is tac welded on top. The weld broke.
Yes, you need to open the floor to access the nut to remove the bolt. Make sure you cover the hole back up when you are done.
Also, replace the nut and bolt.
FERLINM
  • 5 POSTS
Is there a space in the subframe after I open the floor or do I need to cut a hole in the subframe too?
  • 52,797 POSTS
When you open the floor, the nut will be right there. No further cutting needed.
FERLINM
  • 5 POSTS
Thanks.
  • 52,797 POSTS
You are welcome.
Always glad to help.
