How to install toggle switch
TROY CLARK2
  • 1994 FORD ESCORT
  • 1.4L
  • 4 CYL
  • FWD
  • 29,000 MILES
I would like to know how to install a toggle switch for my ignition.
Do you
have the same problem?
Tuesday, May 24th, 2016 AT 7:18 AM
CARADIODOC
  • EXPERT
If you're trying to do this because the screwdriver-like end of the lock cylinder broke, you're better off getting that part. To bypass the ignition switch, you need two switches; one for the ignition and one for the starter. I'll have to dig up a wiring diagram to see which wire colors are involved. By doing this, you'll lose the bulb test feature for the red "Brake" warning light.
Tuesday, May 24th, 2016 AT 7:24 PM
Recommended Guides
