How to install a cooling fan with toggle switch
CONSTANCTEE GRES
  • 2003 JEEP GRAND CHEROKEE
  • 4.0L
  • V6
  • 4WD
  • 145,000 MILES
Overheating, replaced thermostat, radiator and hoses, water pump, relay.
Do you
have the same problem?
Thursday, October 20th, 2016 AT 2:04 AM
AL514
  • EXPERT
How often does the Jeep overheat? Everytime you drive it?
Adding a toggle switch is not going to help the problem, if anything, driving it like this (overheating every drive) is going to fry the headgasket if its not already gone, which is sounds like it is. I would address the real issue first before you cause major damage to the engine and have to replace that. There goes big money.
Thursday, October 20th, 2016 AT 2:19 AM
Recommended Guides
