Cigarette lighter socket repair
WPELLAMATT
  • 2005 CHEVROLET IMPALA
  • 75,000 MILES
Ashtray removal to detach harness, unable to remove ashtray to remove harness to change lighter socket?
Sunday, March 11th, 2012 AT 4:51 AM
KHLOW2008
  • 41,815 POSTS
you are to use a dremel tool to cut the locking tabs off then just pull the socket out here are diagrams for both styles of lighter socket in dash and in the ashtray. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Sunday, March 11th, 2012 AT 7:47 AM
PMASSINGILL47
  • 10 POSTS
  • 2000 CHEVROLET IMPALA
  • 3.8L
  • V6
  • 217,500 MILES
Need to know step by step how to remove the old cigarette lighter socket and install a New one.
Friday, October 26th, 2018 AT 1:49 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
They actually make a tool that inserts into the socket to release and slide out to change it.
PMASSINGILL47
  • 10 POSTS
Can you tell me alittle more what is the tool called so I wouldnt have to take the console apart?
SATURNTECH9
  • 30,870 POSTS
Amazon had the the tool I am talking about it goes in the hole and pushes in the two retaining prongs and helps you slide the old one out. They work really good. Dremel tool
PMASSINGILL47
  • 10 POSTS
Thank you that way I dont have to remove the console is that correct?
TWELVEPAWZ
  • 2002 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 62,000 MILES
How do I remove/replace console cigarette lighter?
BLUELIGHTNIN6
  • 16,542 POSTS
The first step is to remove the center console. Next, remove the power wire, ground wire, and light. The power wire and ground wires have a push clip to release them, and I had to wiggle it considerably to get it to come loose. The light is removed by turning it a quarter turn and pulling down gently.
Then, unscrew the ring located on the bottom of the lighter. After that, the assembly should be loose, and the socket and light ring can be removed from the top. The other pieces are removed from the bottom.
SATURNTECH9
  • 30,870 POSTS
Yeah that's the type of tool the dealers use to remove them.
PMASSINGILL47
  • 10 POSTS
Thank you that is really a big help.
SATURNTECH9
  • 30,870 POSTS
Your welcome glad to hear it please tell all your friends about us.
THOMPSON1231
  • 2007 CHEVROLET IMPALA
  • FWD
  • 74,000 MILES
My cigarette outlets dont work in my 2007 impala. I have 3 outlets, one in the median and 2 in the dash under the radio. I've already checked my fuses. What could it be?
FIXITMR
  • 9,990 POSTS
It is your AUX fuse 20 amp that is out. Here is a guide to help you check for power.
Cheers
OLD SCHOOL MECHANIC
Tool is available at parts store. Found mine at AutoZone $20.00 including new lighter socket.
Sunday, April 11th, 2021 AT 7:12 AM
  • 108,179 POSTS
Thanks for the addition to the link. I'm sure it will help others.
Tuesday, April 13th, 2021 AT 9:09 PM
