How to get a busted oil drain plug out.
KYWALK
  • 2008 GMC SIERRA
  • V8
  • 4WD
I was trying to take out my oil drain plug and busted the head, the rest of it is still in there. I've tried a screw extractor but had no luck. Any suggestions as to what next?
Do you
have the same problem?
Wednesday, September 30th, 2015 AT 7:54 AM
CJ MEDEVAC
  • EXPERT
INSURE THERE ARE NO FUEL LEAKS
HAVE A FRIEND AND A FIRE EXTINGUISHER HANDY!
*****DO THIS OUTSIDE, AWAY FROM YOUR DWELLING!*****
WE WANT TO BE ABLE TO LIVE IN OUR HOUSE, AND KEEP OUR CARS IN THE GARAGE LATER ON, SO BE SAFE!
I'M GUESSING WHEN YOU DRILLED IT FOR THE EXTRACTOR THE OIL DRAINED OUT?
IF THE OIL IS OUT OF IT ********(DON'T TRY THIS IF THE OIL IS STILL IN IT)
MAYBE USE A PROPANE TORCH (PLUMBING TORCH)
HEAT CIRCLES AROUND THE PLUG (1/2 INCH OUT OR SO) DO NOT HEAT THE PLUG!
IT'S A "FEEL KINDA THING" W/ EXPERIENCE, SO IT'S HARD TO EXPLAIN AND KNOW WHEN TO GIVE UP
LETS START OUT WITH 10 SLOW CIRCLES (30 SECONDS OR SO), THIS WILL EXPAND THE PAN METAL, HOPEFULLY LEAVING THE PLUG COOLER AND SOMEWHAT CONTRACTED
GIVE THE TORCH TO YOUR PAL AND QUICKLY INSTALL THE EXTRACTOR AND ATTEMPT TO TURN IT OUT.
NO LUCK
REMOVE THE EXTRACTOR AND COOL IT OFF (DON'T WANT IT TOO HOT, OR IT WILL BREAK)
TRY 20 CIRCLES, MAYBE 45 SECONDS-A MINUTE
PASS THE TORCH TO YOUR PAL, INSTALL EXTRACTOR IN FAST (WHILE IT'S STILL GOOD AND HOT) ATTEMPT TO TURN IT.
I WOULD NOT HEAT IT MUCH MORE THAN THAT
IF THIS FAILS, REMOVE THE PAN AND LET AN AUTOMOTIVE MACHINIST GET IT OUT.
THE MEDIC
Wednesday, September 30th, 2015 AT 9:14 PM
Recommended Guides
