How many quarts of transmission fluid?
DONNASENSKE1964
  • 2003 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 64,000 MILES
I do not have the owners manual for this car and want to change the transmission fluid. Thanks !
Do you
have the same problem?
Sunday, July 6th, 2008 AT 9:42 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,554 POSTS
Hey DONNASENSKE1964,
The entire transmission takes about 12 quarts but if you are just doing the pan and filter it will take about 5.
Fluid Types
Transmission Fluid Type
Type .................... DEXRON III or Equivalent
Capacities
Transmission Fluid
Pan Removal .................... 6.5L (6.9 Qt)
Overhaul .................... 9.0L (9.5 Qt)
Dry .................... 12.2L (12.9 Qt)
Here is a guide showing you how to do the job if you are replacing the filter.
You will need to raise the vehicle to gain access to the drain plug on your trans axle. Place a container underneath the plug (make sure it can hold 6 quarts of fluid). Replace the fluid with Dexron VI or equivalent ATF (please note of any metal fragments in the transmission fluid as this will indicate the level of wear). Fill to 75% capacity to account for any fluid left in the transmission. Move through all gear selections while engine is running 2 times pausing for 10 seconds between selections. Place back into park and recheck for proper fill while the engine is idling. Take it for a drive at both stop and go traffic and on expressway to ensure fluid has properly circulated. Upon return, Recheck again while idling in park.
Please let us know happens so it will help others.
Best, Ken
Tuesday, February 14th, 2017 AT 7:35 AM
ESERVI01
  • 4 CYL
  • FWD
  • 87,400 MILES
Transmission problem
2003 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 87400 miles
I am debating changing the transmission fluid on my 2003 chevy cavalier. It has 87,000 miles on it and I'm not sure if the fluid has ever been changed. There is no burnt smell or signs of slipping, but I've read that replacing the old fluid with new fluid could create a problem. The majority of the miles are highway miles and the car has been driven very conservatively. Should I change the tranny fluid?
Tuesday, February 14th, 2017 AT 7:36 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Fluid change will not create problem not changing will. GM says 100K miles
VINCIA1
  • 8 POSTS
  • 82,000 MILES
Greetings. Our car was driven in stop-and-go traffic without incident today for roughly forty minutes, then it was in the garage with the engine shut off for a half hour, then it was driven roughly a mile in stop and go traffic when it stalled completely and now will not start (it won't turn over completely). The man who towed the car home mentioned the assumption that the problem is the ignition†within the last two weeks we had the transmission fluid flushed and replaced, and we read that a flush can reveal transmission problems that were not noticed before.
We called the dealership to make an appointment and the first thing the service associate said is we would be looking at a minimum of $125 for diagnostics, and we don't know whether or not the best thing to do is just drop off the car and see what they tell us.
Thanks for reviewing this!
SATURNTECH9
  • 30,870 POSTS
Yes a transmission flush can clog the pressure control solenoid etc. Also move debris from on place to another causing other issues.I dont belive in transmission flushes. So you want to know if you should drop the car off at the dealer?My question is were you thinking about trying to figure this issue out yourself.I dont see how a transmission flush can cause the symptoms you have though.
VINCIA1
  • 8 POSTS
  • 83,000 MILES
Greetings. I recently went to Jiffy Lube and received "Automatic Transmission Service Fluid Exchange." After some quick online searches, there is a lot of advice against doing a "flush" as it can damage the transmission. I called Jiffy Lube and they confirmed the service is classified as a "complete flush." Should I be concerned?
CARADIODOC
  • 33,699 POSTS
Not unless you have a problem. Too many people experience some minor transmission shifting issue and think a flush will solve some mechanical problem that has already developed. All the flush will do is remove varnish buildup and debris.
In some cases a problem resulting right after a flush can be attributed to something that was worn and that wear was masked by varnish buildup. Cleaning that varnish out exposes the underlying wear that leads to a problem. The flush, in that case, did not CAUSE the problem. It merely made it apparent. The natural response from uninformed people is to assume it's a new problem caused by the flush. 50 percent of customers will understand that explanation. The other 50 percent will assume the mechanic is lying and refuse to listen to the explanation because it's going to result in repairs someone else isn't going to pay for.
My limited experience with flushes is if you already have a problem, a flush usually isn't going to solve it. If you don't have a problem, a flush might be good maintenance but it is not likely to create a problem.
W_HASHA
  • 2002 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
  • FWD
  • 20,000 MILES
Can't find it in the book.
Wednesday, April 3rd, 2019 AT 3:25 PM (Merged)
  • 31,938 POSTS
I get 9 liters for a complete o/haul so start with 5 and run and check should be around 6.5 to 7.5 for a drain and refill as you don't drain what is in the torque converter and used Dextron VI transmission oil.
CPIPKIN
My daughter ran her transmission fluid completely out to where the trac off light is on and I would like to know how many quarts will it take to fill it up even the tort
Monday, December 2nd, 2019 AT 4:52 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
A dry fill will take approximately 12.9 quarts of Dexron III auto tranny fluid. Here is a guide that will help you change it.
BECKY19872009
  • 2001 CHEVROLET CAVALIER
I have a 2001 chevy cavalier and when I drove for a little while it sort of stalled and wouldnt go over 15 mph I put 3 quarts of transmission fluid in and drove at least 6 blocks and it was dry like I didnt add any at all what could be the problem?
FIXITMR
  • 9,990 POSTS
See any leaks anywhere? Sounds like it's pouring out of somehwere?
BECKY19872009
Thats what I thought too, but no I dont see any leaks anywhere. Is that the only thing it could be or can it be something else?
FIXITMR
  • 9,990 POSTS
Could be going into radiator thru cooling tubes. See if the oil is in coolant overflow bottle.
FIXITMR
  • 9,990 POSTS
And are you sure you put added fluid it in the right place?
BECKY19872009
Yes I put the fluid in the right place but I will check overflow bottle if thats the case what can be done about this?
TONIRGREGG
2001 Chevy Cavalier 6 cyl Automatic
So, when I put my foot on the gas the engine revs up and I have to take my foot off the gas so it can shift gear. I have to do this twice before It really starts to go. The guys at the Auto parts store say the tranny mught be slipping. I also have to keep putting tranny fluid in it. It never seems to get full. What is wrong with my car.
Monday, December 2nd, 2019 AT 4:53 PM (Merged)
  • 108,014 POSTS
When was the last time the trans was serviced? Also, I want you to check the radiator coolant to see if there is any ATF mixing with the coolant.
TONIRGREGG
It hasnt been serviced since I bought it in jan and there is no tranny fluid mixing with the coolant. I am going to have it looked at in 2 weeks but am having a hard time driving it in the meantime
