my clutch on my 99 prelude?
1999 HONDA PRELUDE
CHEECH6922
  • 7 POSTS
my 99 prelude sh is having shifting problems. on the first gear it shifts ok but theres a wierd buzz noise when i clutch. then when i clutch to shift to second gear it doesnt goin or it goes in sort of rough. sometimes it makes a wierd zzzzzzzzcrk noise when it does go in gear. it does this with all the gears. is it time fora new clutch.
Nov 1, 2006 at 3:28 PM
BRUCE HUNT
  • CAR REPAIR CONTRIBUTOR
  • 3,754 POSTS
Two things to try. First, put the car in first gear and start the car. Hold your foot on the brake and slowly let out the clutch. Note if the engine just flatout dies or if it hesitates like the clutch is slipping.
Secondly, I would look at the clutch fluid level. It sounds like it is low. If so, you need to look at whether it is the slave unit located by the tranny or the master unit where the fluid resevoir is located. It could be either one. Note wear any fluid could be leaking.
Nov 1, 2006 at 3:48 PM
COMADOG
  • 5 POSTS
I had the same prob. and it was the throw out bearing one day i forced it into gear and it busted
Nov 1, 2006 at 5:41 PM
