2001 Honda Prelude help
LILLUDA803
  • 2001 HONDA PRELUDE
Computer problem
2001 Honda Prelude 4 cyl Front Wheel Drive Manual
vtec wont engage cruise control fuse keeps blowing when I turn on the car battery light along with brake light both are dim
Do you
have the same problem?
Thursday, September 4th, 2008 AT 10:56 PM
KHLOW2008
  • EXPERT
Hi lilluda803,
There is a shorting somewhere and it is not going to be easy getting to the bottom of it.
Did you do anything prior to this happening?
I guess you re refering to Fuse # 13 ( 15 A ) under dash fuse. You need to check the following component circuits.
1. Cruise control
2. Turn Signal switch to flasher relay.
3. Meter clusteer
4. Driver multiplex controls.
5. Passenger multiplex controls.
Sunday, October 12th, 2008 AT 1:01 AM
Recommended Guides
