1998 Honda Prelude car won't start up
PINOPONI
  • 1998 HONDA PRELUDE
Engine Mechanical problem
1998 Honda Prelude 4 cyl Automatic
When I turn the ignition to start up my car, the radio and windshield wipers work fine, when turned all the way to start, it makes a fast clicking sound, the dash board lights flicker dim but the car doesn't start, and when left in the II position the oil and battery lights come on? help please? Thank you!
http://www.2carpros.com/forum/automotive_pictures/225944_Candace_M_Rach_1.jpg
Do you
have the same problem?
Sunday, August 10th, 2008 AT 11:37 AM
KHLOW2008
  • EXPERT
Hi pinoponi,
To whom should I be addressing? Left, right or center?
The battery seems weak or the terminal connections are bad. Clean the terminals to see if it helps. A voltage reading of the battery would be required to confirm if it is low in charge.
If a jump start solves the problem, you might need to replace the battery. Get the battery tested to see if it is still good.
Saturday, August 16th, 2008 AT 11:56 AM
Recommended Guides
