Transmission Problem?
DEBBY
  • HONDA
I have a 2002 Explorer XLT 4wd (mileage 37,000) that quit running suddenly and had to be pushed into the garage. It must be towed to the repair shop, and so I would like to have an idea of what may be going on.
When I try to drive, the car is stuck in 4wd low and remains running for only about 1-2 minutes before the engine quits. I am able to reverse and shift into drive.
A couple of weeks ago, I felt the gears slip while driving around 20 mph.
The slip was corrected after stopping and then shifting back into drive.
Does this sound like a transmission issue?
Is this a common problem with Explorers?
Also, my left rear turn signal must frequently be replaced. And my interior panel illumination dims in and out. Is there a larger problem here?
Are these two issues possibly connected?
Do you have any idea about repair costs for any of above issues?
Thank you, and I appreciate any advise!
Do you
have the same problem?
Wednesday, February 8th, 2006 AT 5:31 PM
JACK42
Post in the correct forum
Thanx
Thursday, February 9th, 2006 AT 2:04 PM
Recommended Guides
