Horn relay location
STU710
  • 2005 HONDA ODYSSEY
  • 3.5L
  • V6
  • 180,000 MILES
Cannot find the horn relay for my van. I found the fuse. The car horn is not working.
Saturday, January 14th, 2017 AT 8:30 AM
STU710
  • 6 POSTS
It is a Touring Edition.
Saturday, January 14th, 2017 AT 9:27 AM
HMAC300
  • 48,601 POSTS
See picture for where it is. however, it may be inside the module and not replaceable and needing a scan for codes by a mechanic. check wire leading to horns either with a test light or volt meter for power.
See the guides below for using a voltmeter and test light, also for testing wiring
Wiring diagram is attached below
Saturday, January 14th, 2017 AT 9:41 AM
STU710
  • 6 POSTS
That would explain why I can't find it. Thanks.
Sunday, January 15th, 2017 AT 7:34 AM
STU710
  • 6 POSTS
Got the horns off and back traced the wiring and it goes to the Fuse Box. Can't find the relay still
Sunday, January 15th, 2017 AT 9:02 AM
HMAC300
  • 48,601 POSTS
Reread my reply if it's in the module you will never find it as it's an encased relay
Sunday, January 15th, 2017 AT 9:12 AM
STU710
  • 6 POSTS
Gotcha. Thanks.
Sunday, January 15th, 2017 AT 10:17 AM
STU710
  • 6 POSTS
I'll try testing the wires to the horn to see if they get voltage. Thanks again
Sunday, January 15th, 2017 AT 10:19 AM
HONDAHORN
  • 2000 HONDA ODYSSEY
Horn starting blowing on its own, then blew #47 fuse. Replaced fuse but when I try to blown horn, fuse blows again. What is the cause and the fix?
Wednesday, November 21st, 2018 AT 4:46 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Check the horn and its relay.
DOROTHY49
  • 1995 HONDA ODYSSEY
  • 4 CYL
  • 100,000 MILES
The horn goes off when it rains.
Check the horn wiring connector and the horn relay
