Periodic starting issues
JBAKER6498
  • HONDA CRX
I have a 89 honda crx si with ~206,000 miles. The car has been well maintained and runs perfect after it starts. I believe it is a fuel system issue. When I turn the key to the on position, most of the time you can hear the fuel pump turn on. If it does the car starts no problem. Sometimes it doesn't though. When this happens I have to wait between 15 min to an hour and try agiain for the pump to turn on. Any comments are greatly appreciated.
Do you
have the same problem?
Monday, September 24th, 2007 AT 1:17 PM
SIOMY
Check main relay, fuel presure.
Monday, October 8th, 2007 AT 7:18 PM
Recommended Guides
