2000 Honda Civic No power.
CRISTINASZILAGYI
  • 2000 HONDA CIVIC
2000 Honda Civic 4 cyl
Background:
- no warning symptoms
- parked
- when trying to crank it up, no power, no sound, nothing.
Done so far:
- checked battery - good.
- checked fuses under the hood - good.
Do you
have the same problem?
Monday, September 21st, 2009 AT 8:24 AM
F4I_GUY
  • EXPERT
Check to see if the starter is getting the trigger signal (the little wire on the starter)
Monday, September 21st, 2009 AT 7:37 PM
CRISTINASZILAGYI
Tried to turn on the lights (interior, headlights), none came on. When pushing down on the hazard light switch, it made an unusual sound, like a "sparking" type sound, and I traced it to a relay. Does this mean that relay is bad, and should I replace it?
Monday, September 21st, 2009 AT 8:24 PM
Recommended Guides
