1998 Honda Civic Front Door Help
EMAIRE
  • 1998 HONDA CIVIC
1998 Honda Civic
My driver side front door does not open. I think the latch is stuck. How do I get the door open to replace the assembly?
Do you
have the same problem?
Tuesday, January 6th, 2009 AT 3:00 PM
KHLOW2008
  • EXPERT
Hi emaire,
This is not going to be easy. You would need to get the door panel off or slightly away so that you can get your hands under the panel and onto the latch linkages to check if any is detached and can open the unlock the door.
If the linkages are ok, the lock needs to be demolished by breaking the plastic part on the latch assy to release the locking tab.
Sunday, January 11th, 2009 AT 2:12 PM
Recommended Guides
