1998 Honda Civic 1998 Honda Civic LX power lock will not wo
SUKALSR
  • 1998 HONDA CIVIC
Electrical problem
1998 Honda Civic 4 cyl Two Wheel Drive Automatic
power lock will not work on any door. Fuse under hood is good. Ck door lock control from my other honda stll no good I do not have a remoe entey please help
stan
Do you
have the same problem?
Wednesday, January 6th, 2010 AT 1:00 PM
BUDDYCRAIGG
  • EXPERT
What sub model do you have and I'll pull the schematics for you.
Wednesday, January 6th, 2010 AT 4:38 PM
SUKALSR
1998 civic lx
Wednesday, January 6th, 2010 AT 9:21 PM
BUDDYCRAIGG
  • EXPERT
If you don't get any movement when trying to lock, or unlock then I suspect the problem is going to be in the switch built onto the drivers door lock motor.
Unplug the 4 wire connector at the motor and then try the master switch in both directions to see if you get any movement.
Wednesday, January 6th, 2010 AT 10:08 PM
SUKALSR
Removerd the wire to drivers door no responce also tryed master switch from my other car still no respose switch worked on the other car.
Thursday, January 7th, 2010 AT 5:20 AM
SUKALSR
Did more ck and found there was no ground jumped blk wire to ground and it started working
Thursday, January 7th, 2010 AT 8:31 AM
BUDDYCRAIGG
  • EXPERT
Yeah, that can do it.
Glad it was a cheap fix.
Thursday, January 7th, 2010 AT 10:56 AM
Recommended Guides
