1995 Honda Civic Honda won't start up right away when cold.
JILLY
  • 1995 HONDA CIVIC
  • 4 CYL
  • FWD
  • 202,000 MILES
I've owned the car for thirteen years and never seen this problem occur. I just replaced the starter, new radiator, oil gasket, fuel filter, spark plugs and battery. When starting the vehicle it whines, all belts are rotating. It takes a good six trys to get the car to start. I thought it might be a wiring issue. It could be the fuel pump but I'm wondering if anyone else has any ideas. Thanks for your time. Best, Jill
Do you
have the same problem?
Wednesday, March 4th, 2009 AT 10:31 PM
F4I_GUY
  • EXPERT
Well there are a few possibilities. Without getting too crazy with ideas you should do some basic tests when the vehicle takes a long period of time to crank.
Measure your fuel pressure at the rail, it should be around 36-38psi.
Check for good bright strong spark when the vehicle is cold.
If it passes both of these tests reply back and I will further guide you into what it may be.
Thursday, March 5th, 2009 AT 2:06 PM
Recommended Guides
