1995 Honda Civic crankshaft
NAILMAN52
  • 1995 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
Is the crankshaft bolt lefthand or right theard. And is there a TDC mark on the crank pulley.
Do you
have the same problem?
Tuesday, January 6th, 2009 AT 10:23 PM
KHLOW2008
  • EXPERT
Hi nailman52,
Crank pulley bolt is right handed thread and is torqued at 150 ft. Lbs so at times is not easy to remove without and special tools to hold the pulley.
Yes, crank pulley TDC mark is the 2 slots with white mark and corresponds with the timing belt cover outer indicator. On the timing belt lower gear, there is a mark on oil pump housing to indicate TDC as well.
Sunday, January 11th, 2009 AT 2:44 PM
Recommended Guides
