1995 Honda Civic
GLENNGRAMMER
  • 1995 HONDA CIVIC
Air Conditioning problem
1995 Honda Civic 4 cyl Manual
I have a 1995 Honda Civic 5 speed 4 cylinder, The radiator fan, conditioning fan, a/c compressor won't come on. Do you have a suggestions?
Do you
have the same problem?
Monday, August 11th, 2008 AT 11:38 AM
KHLOW2008
  • EXPERT
Hi GlennGrammer,
Being a manual version, the radiator fan would only work when the fan switch is activated as the coolant reaches operating temperature. Test the fan relay for power supply to fan motor and test if motor is ok.
If Ac compressor is not working, the condenser fan would not come on.
You need to check if there is enough freon in the system.
Wednesday, August 13th, 2008 AT 9:24 AM
Recommended Guides
