1994 Honda Civic Only changed O2 sensor now car wont start!
AMARTINEZ209
  • 1994 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 166,956 MILES
I have a 94 Honda Civic DX. I have just changed the O2 sensor now the Car wont start everything was in running condition before I did this. Battery, distributor, plugs, wires, fuel filter and pump and relay are all new. What could be the problem?
Do you
have the same problem?
Friday, May 29th, 2009 AT 7:49 PM
An oxygen sensor will not prevent the engine from starting-backtrack your work
Friday, May 29th, 2009 AT 8:15 PM
AMARTINEZ209
Thanks for your help I back tracked on all my work and found the problem. Don't I feel dumb Lol thanx for the help
Friday, May 29th, 2009 AT 9:24 PM
What's the fix maybe others will learn from it?
Saturday, May 30th, 2009 AT 12:44 AM
AMARTINEZ209
Once I back tracked my work I found the problem! The fix was a faulty wiring to the starter (12v wire, a ground wire) once I replaced the faulty wiring the car started right up no problem runs great thanx for the help
Sunday, May 31st, 2009 AT 4:59 PM
P1494 Leak Detect Pumps SW or mechanical fault
Leak Detection Pump (LDP) switch operation is monitored immediately after a cold start, with ambient temperature 40-90 degrees F and engine coolant temperature within 10 degrees F of ambient temperature. DTC will set in Powertrain Control Module (PCM) memory when PCM does not sense a change in switch state when LDP solenoid is energized.
Possible causes are:
Leak or obstruction in LDP vacuum supply.
Defective LDP.
LDP switch senses circuit open, shorted, corroded or defective PCM. The switch connector is a very common problem. So it seems the code is set at startup, when certain temperature parameters are met - which may be why the dealership said it's ok to drive.
Sunday, May 31st, 2009 AT 8:04 PM
Recommended Guides
