1994 Honda Civic no start
PIAZZA
  • 1994 HONDA CIVIC
Engine Performance problem
1994 Honda Civic 4 cyl Manual
replaced battery, 80A Fuse for battery, but the engine still does not turn over Drove it for a few weeks then it would not start the next day, but notice the clock had stop for a little while. Help
Do you
have the same problem?
Tuesday, June 16th, 2009 AT 3:13 PM
F4I_GUY
  • EXPERT
I assume it doesn't crank.
Check to see if you have battery voltage at the starter (the larger wire should have constant voltage)
Have a helper crank the engine over and hold it in the crank position. The smaller wire on the starter should now have power. If it doesn't, check the ground wire on the transmission, if that's fine, replace the starter.
Tuesday, June 16th, 2009 AT 5:02 PM
Recommended Guides
