1994 Honda Civic Engine won't start
TAMPATEXAN
  • 1994 HONDA CIVIC
Engine Mechanical problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual
While driving to work, the car quit running. Had it towed home. It turns over fine, but will not start. Fuel is present and I loosened the fuel line at the engine log and got fuel out, so pump seems to be working. No spark at plugs. Obviously seems to be ignition, but what should I check first? Also, how do you get the rotor off? It doesn't come off easily, and I don't want to break it. Thanks in advance.
Do you
have the same problem?
Tuesday, March 24th, 2009 AT 10:30 AM
F4I_GUY
  • EXPERT
To remove the rotor you have to turn the engine over until the philips screw exposes it's self. The rotor will face towards the front of the vehicle when the screw can be removed.
You either have an ignition coil or an ICM that has failed, or possibly both. Sometimes they take each other out when one fails.
You can check the resistance of the ignition coil, and continuity through the ICM.
Tuesday, March 24th, 2009 AT 5:11 PM
Recommended Guides
