2008 Honda Accord Alignment - Slight turn - Tires
BIGCHRIS777
  • 2008 HONDA ACCORD
  • 6 CYL
  • FWD
  • 26,850 MILES
Just purchased 2008 Accord ex l v6 w/ 26850 miles and clean carfax. I realized it was turning slightly to the right on freeway and on most roads. I brought it back to the dealer the day after purchase because they said they would do an alignment. Well they DID NOT DO the alignment because they said they test drove it and nothing is wrong because it is normal for this car to turn to the right a little after 7 seconds. Is this true?
Also to consider: This car has 20" rims and larger tires then recommended by HONDA. Could this affect anything with alignment or anything else in the future? Thanks --C
Do you
have the same problem?
Monday, June 15th, 2009 AT 1:28 AM
RACEFAN966
  • EXPERT
No not normal. You should have the tires rotated and then if that don't help then get it aligned and insisted on it. Let me know how it goes.
Monday, June 15th, 2009 AT 2:01 PM
